2002 Dodge Caravan Water leak from passenger underside
MRSTRAIN14
  • 2002 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 160,000 MILES
When coming to a stop, there is a trail of water drops behind the vehicle and what appears to be a water leak from the passenger underside. There are two hoses running down which connect to two metal pipes which in turn run to the rear of the vehicle.
The leak appears to originate from higher up with the water then running down and dripping from these pipes.
Assistance is appreciated!
Saturday, August 7th, 2010 AT 1:40 PM
  • 109,885 POSTS
Is it coolant or water? Could it be from the AC?
Saturday, August 7th, 2010 AT 10:57 PM
MRSTRAIN14
Definitely not coolant, appears to be just water, ac is my first guess but don't know if it means a blockage somewhere or a more serious problem.
Sunday, August 8th, 2010 AT 10:36 AM
  • 109,885 POSTS
If it is water, chances are the drain hose is plugged with dirt. Under the hood on the passanger side, you will see a rubber hose pointing toward the ground check it to see if there is a blockage. That is most likely the problem.
Let me know what you find.
Monday, August 9th, 2010 AT 12:36 AM
MRSTRAIN14
Thanks Joe, I will check it out and let you know. I appreciate the help.
Monday, August 9th, 2010 AT 9:15 AM
  • 109,885 POSTS
Glad to help. Let me know what you find.
Tuesday, August 10th, 2010 AT 12:23 AM
