2002 Dodge Caravan transmission lid leaking
2002 DODGE CARAVAN
CONFUSED01
Transmission problem
2002 Dodge Caravan 6 cyl Wheel Drive Type unknown Automatic 99913 miles
The lid that is removed when you are changing out the fluid, is leaking on one corner because my husband messed up one of the screws that hold it in place. Can it be fixed?
Dec 19, 2007 at 9:29 AM
BMRFIXIT
  • 19,053 POSTS
[quote:a68575cada="confused01"]Transmission problem
The lid that is removed when you are changing out the fluid, is leaking on one corner because my husband messed up one of the screws that hold it in place. Can it be fixed?[/quote:a68575cada]
tap new over size bolt
Dec 19, 2007 at 9:37 AM
