2002 Dodge Caravan Trans Downshifting
101,000 MILES • 6 CYL • FWD • AUTOMATIC
DSIMMERS
I recently changed trans filter as routine maintance. Most of time now when coming to stop it downshifts and not smooth. What could be causing this as a result of filter change. Fluid is at proper level.
Mar 2, 2009 at 10:57 AM
BMRFIXIT
  • 19,053 POSTS
Was the correct tranny fluid used if not drain and refill try and adjust the band
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_227.jpg
Mar 2, 2009 at 11:35 AM
