2002 Dodge Caravan Touble code: P0455--EVAP leaking
75,000 MILES • 4 CYL • FWD • AUTOMATIC
HNZHENG
Engine light on, trouble code: P0455:
EVAP large leak detected. There are 4 possible problem:
1. Defective fuel cap.( I change a new one already).
2. EVAP canister broke, hose craked( How can I find the craked hose?)
3. vent solenoid defective( How can I find it?)
4. Vacum leak at eigine( How can I find vaccum leak? Where are the engine vaccum hose located? I'll like to check these vaccum hoses first.)
I'll appreciate you can answer above 4 questions!
Thanks!
Hsiao
Sep 24, 2008 at 2:59 AM
BMRFIXIT
  • 19,053 POSTS
A smoke machine is in need for most of these tests
not an easy thing to locate
visually check the lines and hoses and if nothing found u need the help of the smoke machine to locate the leak
Sep 25, 2008 at 1:38 PM
