Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Caravan
Engine
Camshaft
Timing
2002 Dodge Caravan Timing belt
2002 DODGE CARAVAN
1,800 MILES • 4 CYL • 2WD • AUTOMATIC
RYANNEWBOLD
MEMBER
1 POST
After replacing the Timing belt the caravean wont run. What do you think I should do to fix it
Also there is no spark.
Feb 18, 2008 at 2:34 PM
SHOWGUN101
MEMBER
check your time marks if they are right check your crank sensor you can take it auto zone they can test :D
Feb 18, 2008 at 2:47 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
