2002 Dodge Caravan terminal relay
126,000 MILES • 6 CYL • 2WD • AUTOMATIC
JAWZ1962
when trying to start car, don't start makes a click sound, already replaced starter and alternator and check battery and it's good, still not starting.............Do you think it can be the relay terminal that won't let it start or the ignition switch?
Mar 28, 2010 at 1:25 AM
LEGITIMATE007
  • 5,121 POSTS
could be the terminal yes, as a matter of fact, it can be any of the connections from the battery to the alternator to the starter too, a little corrosion will cause this also, check all the cables and wires associated with these items
Mar 28, 2010 at 5:19 AM
