2002 Dodge Caravan Staring the engine
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
SKEETERBROOKE
Until this week, all we had to do to start the car was turn the ignition switch and the car started right up. The past few days, when we trun the switch the car cranks but does not fire. After releasing key and pumping gas pedal once, then retrying the start, it will start to run. What is causing this ?
Feb 15, 2008 at 11:03 PM
BMRFIXIT
  • 19,053 POSTS
I would start
by checking the tune up
your mileage indicate that a tune up is due
scan van for codes
good luck
Feb 17, 2008 at 1:48 AM
