2002 Dodge Caravan slips out of gear
2002 DODGE CARAVAN
DEANO321
Transmission problem
2002 Dodge Caravan Two Wheel Drive Automatic
while driving, the transmission slips into neutral, and then goes back in.
Mar 3, 2010 at 2:37 AM
OBXAUTOMEDIC
  • 3,711 POSTS
When was your last transmission service?
Is engine light on? If so go by your local parts store and have them pull codes. Write them down and post here in forum.
Check the fluid, good fluid looks reddish, bad or burnt fluid looks brownish and smells burnt.
If fluid looks and smells burnt then have fluid and filter changed. Will most likely fix the problem.
Mar 3, 2010 at 3:00 AM
