2002 Dodge Caravan removal of door panels
ANZINGER
Interior problem
2002 Dodge Caravan Two Wheel Drive 82000 miles
How can I remove the door panels on the front passenger door to see why the automatic window is sticking?
May 23, 2009 at 6:57 AM
BMRFIXIT
  • 19,053 POSTS
DOOR TRIM PANEL
Removal
Remove the plug and remove screw attaching door pull cup to inner door panel.
Remove switch bezel and disconnect power window/memory switch.
Remove screws attaching trim panel to door from below map pocket.
Remove screw holding door trim to door panel from behind inside latch release handle.
Disengage clips attaching door trim to door frame around perimeter of panel.
Lift trim panel upward to disengage flange from inner belt molding at top of door.
Tilt top of trim panel away from door to gain access to latch linkage.
Disengage clip attaching linkage rod to inside latch release handle.
Separate linkage rod from latch handle.
Disconnect the power door switch, courtesy lamp electrical connectors.
Remove front door trim panel from vehicle.
May 24, 2009 at 12:24 AM
