2002 Dodge Caravan rattle in fornt end
2002 DODGE CARAVAN
106,000 MILES • 6 CYL • 2WD • AUTOMATIC
MDOUMANIAN
replaced struts and struts mounts, and sway bar links also balljoints and still have rattle in front end,outer tie rod end are tight is my rattle inner tie rod or rack and pinion and if so should I replace both or just inner tie rods?
Aug 14, 2009 at 1:41 PM
F4I_GUY
  • 3,302 POSTS
Have you replaced your sway bar bushings?
Aug 14, 2009 at 1:52 PM
