2002 Dodge Caravan radiator removal
13,600 MILES • 6 CYL • FWD • AUTOMATIC
JOHNHEAT
My daughter has this van and a mechanic told her to replace the radiator he would have to disconnect the ac condenser and the power sterring pump, is that true. I have replaced radiators before but never had to do that, HELP
Oct 12, 2009 at 7:11 AM
BLUELIGHTNIN6
  • 16,542 POSTS
you will need to remove the A/C condenser side brackets to radiator attaching screws..then separate the condenser from the radiator by lifting upward to disengage it from the lower mounts .
Oct 12, 2009 at 7:30 AM
