2002 Dodge Caravan problem with Caravan
70,000 MILES • 6 CYL • FWD • AUTOMATIC
TENNANT5
Yesterday our Caravan stopped blowing heat when we had the heater on. We noticed when it was idling that the engine's temperature was normal. However, as soon as we began to drive down the street it climbed to overheating. We added engine coolant because it was very low however, that did not solve the problem of overheating. Any ideas? Could it be the thermostat?
Feb 16, 2009 at 9:36 AM
BMRFIXIT
  • 19,053 POSTS
Need to do a coolant pressure test and check for leaks
also I would remove and replace the thermostat
Feb 16, 2009 at 10:03 AM
