2002 Dodge Caravan POWER STEERING FLUID
SANDYMATA
Steering problem
2002 Dodge Caravan 6 cyl Wheel Drive Type unknown Automatic 118000 miles
I ACCIDENTLY PUT POWERING STEERING FLUID IN THE BRAKE FLUID CONTAINER, WHAT ARE THE CONSEQUENCES, IF ANY? YIKES!
Dec 20, 2007 at 3:43 PM
DODGEGUY43
  • 10 POSTS
[quote:9fc71baf4b="sandymata"]Steering problem
I ACCIDENTLY PUT POWERING STEERING FLUID IN THE BRAKE FLUID CONTAINER, WHAT ARE THE CONSEQUENCES, IF ANY? YIKES![/quote:9fc71baf4b]
DO NOT LISTEN TO THE LAST POST. The 2 fluids are not the same at all. The PS fluid is ATF +4 and the brake fluid is d.o.t 3 glycol based. You will need to replace your master cylinder and all you rubber seals in the calipers.
Dec 22, 2007 at 2:47 AM
