2002 Dodge Caravan Popping sound and misfiring at start, ga
136,000 MILES • 4 CYL • 2WD • AUTOMATIC
SKINNERF3
Yesterday, on a cold night (<32degrees), we started the van and had a popping sound immediately and the engine began misfiring. We found 1 of 4 spark plug wires disconnected from the engine block. We turned off the car and reconnected the wire. When we tried to start the engine again, same things occurs (popping sound and same spark plug wire is found to be disconnected from engine block
Feb 13, 2010 at 9:19 AM
  • 110,248 POSTS
Are you sure you got the plug wires on the correct spark plugs? IF you mixed them up, it will miss.
Feb 14, 2010 at 5:15 AM
SKINNERF3
We had not moved any of them, we just put back the one wire that keeps popping off. How do you know which wire belongs where? Thank you for your reply
Feb 14, 2010 at 8:07 AM
HAHNY1
  • 75 POSTS
when the wire comes off does the spark plug come with it? next time you put it on make sure that it is on all the way they kinda make a click. also maybe one of you could watch the one that comes off while the other starts it to see if something is catching the wire or if its just popping off
Feb 15, 2010 at 3:38 AM
