2002 Dodge Caravan PO352
2002 DODGE CARAVAN
109,000 MILES • 6 CYL • 2WD • AUTOMATIC
POPAWALKER
2002 dodge grand caravan is displaying a PO352 code The check engine light is intermittent usually comes on with hard acceleration accompanied by sluggishness any ideas?
Jan 17, 2010 at 1:39 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Below is the Code Def....
P0352 Ignition Coil B Primary/Secondary Circuit Malfunction.
Here are a few causes that will set the code....
Intermittant problem
Defective Coil
Defective PCM
OR
Defective Connector or Wiring.
Jan 17, 2010 at 1:55 AM
