2002 Dodge Caravan Plastic gas tank
81,000 MILES • 6 CYL • 2WD • AUTOMATIC
BOYTEX
Soon after starting engine there are loud popping noises coming from below the rear floor area. I discovered the bottom of the gas tank was being sucked in by the strong vacuum inside the tank. When I remove the filler cap (With difficulty) air rushes in. What would cause this? Thanks.
Oct 10, 2009 at 6:18 AM
BMRFIXIT
  • 19,053 POSTS
Do you have check engine light on with engine running
and if so scan for codes
suspect defective EVAP system
Oct 10, 2009 at 6:34 AM
