2002 Dodge Caravan no heat
115,500 MILES • 6 CYL • FWD • AUTOMATIC
PDMOOCH
been told that problem is heater door that is broken.
need to replace entire heat unit since is it a total package and heater door is not replaced individually. Is that correct?
Feb 24, 2010 at 1:30 AM
CARADIODOC
  • 34,410 POSTS
Check with the dealer on the availability issue. There should be plenty of good used heater boxes in the salvage yards. You can buy the entire unit or just the part you need.
caradiodoc
Feb 25, 2010 at 8:56 PM
