2002 Dodge Caravan intermittent electrical problems
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
KCIMNEY
For the past 2 years I have had intermittent electrical problems with my van. First, it was the power windows, then the fan for the heat/air. These problems were intermittent in that they would sometimes occur, sometimes not. Not work for several weeks or months then all of a sudden work again. Right now the brake lights are not working. Any ideas?!?!
Jun 19, 2010 at 5:17 AM
  • 110,246 POSTS
I think you have a few different issues. I need you to check the brake light switch. It is located at the top of the brake pedal. Check to see if it is loose, disconnected... ALso, have you checked fuses?
Jun 19, 2010 at 4:19 PM
