2002 Dodge Caravan Intermitent starting
166,000 MILES • 6 CYL • 2WD • AUTOMATIC
HEIST23DRAGON
Awesome website! I have a question about my dodge caravan. My van will start 90% of the time but then will not start and click as if the battery is low. I have replaced the battery and started fine. The Intermittment problem continues. I have read the Haynes manual I have checked connections. What should I check next??
THANKS YOU GUYS ROCK!!
Oct 2, 2008 at 1:43 AM
  • 110,248 POSTS
Hi:
To me it sounds like there is a ground problem or a corroded wire / connection. Hav you replaced the battery cables? Have you inspected the ground to both the engine and the body?
Let me know so I can better direct you.
Oct 3, 2008 at 4:37 AM
