2002 Dodge Caravan Instrument panel bulbs, gas gauge light-
64,000 MILES • 4 CYL • FWD • AUTOMATIC
HOYTBOW
How hard is it to get at these bulbs that light-up your dash gauges, does the whole top of the dash board need to be taken off? Or, can I simply remove the gauge lens plate (without breaking it) and somehow get behind those gauges to replace the burnt-out bulbs?
Thank-you so much for your time and effort!
Tom Podolske
Milton, Wisconsin
Jan 5, 2009 at 2:29 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation.
You will have to take apart the steering column bezel along with a few other components around the gauges, but you will not have to remove the entire dash. You can not get inside of the gauges from the front so removal is necessary for bulb replacement. For detailed instructions on removing and installing the gauge cluster, just let me know if your vehicle is equipped with the electronic transmission range indicator or the manual transmission range indicator (this is the letters D,R,N,P etc.. for gear selection).
Ironically I just had to remove mine from my vehicle to replace the engine light bulb, hehe.
Hope this helps..
Thanks for using 2carpros.com!
Jan 5, 2009 at 4:33 PM
HOYTBOW
In this van....I have the manual transmission range indicator.
Again,
Thank-you, for your effort!
Tom Podolske
Milton, Wisconsin
Jan 5, 2009 at 5:39 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Below are the removal/installation procedures for your vehicle's instrument cluster.
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_88.jpg
FIGURE 4
https://images.2carpros.com/forum/automotive_pictures/261618_fig4_1.jpg
Hope this helps.. Thanks for using 2carpros.com!
Jan 5, 2009 at 10:47 PM
PUNT1959
This is what I did to my van.
2003 Grand Caravan Sport. This works well if you have trouble finding the PC74 (bulb and base together) and just repalce the bulb itself. Also works well if someone wants to use LED lights in place of original lights. Lets you seperate the base from the light bulb itself without too much trouble.
http://www.youtube.com/watch?v=_bf5w3AZR_0
Jan 12, 2013 at 6:07 PM
