2002 Dodge Caravan im stumped
130,000 MILES • 6 CYL • FWD • AUTOMATIC
MR_BOJANGLES
Hi ive got codes p1684 p0106 and p0121 the van will start just fine but as soon as u touch the gas it bogs and or dies.
Apr 18, 2010 at 3:10 AM
CH112063
  • 1,320 POSTS
There is a problem with the TPS on the throttle body. It may be bad, unplugged, or have a wiring problem. Replace it and reset the PCM. The fuel control system is seeing a drop in vacuum as you open the throttle blade but does not get any confirmation from the throttle position sensor so it doesn't do any fuel or timing advance, for safety reasons. Some, most, have a MAF sensor to back it up. It will light the check engine light but get you home in limp-in mode. I hope this does it. I haven't had much luck lately but that must mean I am due. Good luck and thanks
Apr 18, 2010 at 12:48 PM
