How to bypass air conditioning compressor
2002 DODGE CARAVAN
97,000 MILES • 6 CYL • FWD • AUTOMATIC
MARC58
  • 6 POSTS
My A/C compressor seized and the replacement is very costly. Dodge doesn't sell a bypass pulley. But A/C is an option, so how do non-A/C vans bypass the compressor? How can I bypass it? The belt routing doesn't allow for a simple shorter belt.
Apr 29, 2009 at 9:21 AM
  • 110,240 POSTS
Here is a link to the belt routing diagrams to help get started.
https://www.2carpros.com/diagrams/dodge/caravan/2002
I would try a 2 and 3 inch shorter belt and route it below the ac compressor.
Apr 29, 2009 at 2:48 PM
MARC58
  • 6 POSTS
There are a few different diagrams for the 2002 Caravan, probably for different engines. I'll see if I can compare it with my van when I get home tonight.
Thanks.
Apr 30, 2009 at 12:04 AM
  • 110,240 POSTS
Yes, they are for different engines. Let me know what you find when you get home and we'll go from there.
Apr 30, 2009 at 7:20 AM
MARC58
  • 6 POSTS
Thanks. I'm getting discouraged, though. I searched online for a belt for a non-A/C Caravan, and they don't seem to exist. Now I'm wondering if they designed this model without A/C at all. But let's see what I can find under the hood and hopefully I'll get a nice surprise.
Apr 30, 2009 at 7:22 AM
MARC58
  • 6 POSTS
Well, my van matches one of the diagrams on that page, G00094757. There is no non-A/C diagram, but it looks like a shorter belt would work fine. I ended up going with a 3.5" shorter belt, a Dayco 5060825. Belt part numbers have the length in the last three digits in tenths of an inch. Or at least this series of Dayco belts works that way. So I used a 5060790.
The belt rubs the A/C pulley, so I removed just the pulley. This keeps the compressor connected to the lines and prevents contamination, in case I want to pony up to get my A/C back.
It looks like it was designed to have A/C as an option, but I bet they didn't sell any without. The belt is readily available, but is not listed for this application.
So it looks like I'm all set. It was raining today and no belt squeal, so it should be tight enough. And no burning belt smell.
May 5, 2009 at 12:21 AM
