can u help i need the fuel pressure specs?
BENNET
can u help i need the fuel pressure specs for 02 dodge grand caravan sport 3.3 L flex fuel tested with gauge and it is @ 60 psi ( not sure if it is a high reading?) and very erratic (jittery) need info on what gauge readings are to be thru test procedure process. how do you test fuel pressure if it is in the gas tank as part of the fuel pump (that is what i was told is it's location) or just bite bullet and buy new pump
Jul 30, 2010 at 1:17 PM
  • 75,988 POSTS
Specifications
400 kpa (+/-) 34 kpa (58 psi (+/-) 5 psi)
The fuel pressure specification for the 2002 Dodge Grand Caravan Sport with the 3.3L Flex Fuel engine is typically around 48-55 psi for the fuel rail pressure.
Jul 30, 2010 at 1:54 PM
