2002 Dodge Caravan Fuel mileage
2002 DODGE CARAVAN
152,000 MILES • 6 CYL • FWD • AUTOMATIC
DJCOOL
My caravan has 152,000 kms. The fuel mileage is horrible, I get like 300 kms per tank and I used to get 550-600kms per tank. I have changed the oil, the spark plugs, air filter. Now I was told the o2 sensors are probably the cause. Any suggestions??
Thank you very much
Danielle
Mar 5, 2008 at 9:58 AM
BLAZER94BLK
first is there a "check engine" light on, if so the o2 censor could be your problem
Mar 5, 2008 at 10:18 AM
BMRFIXIT
  • 19,053 POSTS
With the new ethanol mixed
gas mileage went down and fuel price going up and up
Not every check engine light caused by an o2 sensor
you need to have it checked for codes
or you can do the key cycle to retrieve the codes
check fuel filler cap
check for fuel leak
check wires
check o2 sensors
and the list goes on and on
codes will help pin point the troubled area and the cause
let me know
Mar 5, 2008 at 10:33 AM
