2002 Dodge Caravan FUEL LINES
78,000 MILES • 6 CYL • FWD • AUTOMATIC
DERRUMBE
I'm experiencing a problem with the fuel going to the injectors on a 2002 Dodge Caravan 3.3 L. I've put in a new pump and filter, but no gas will push through. I've disconnected the lines before the fuel filter and back flush. Air goes through just fine blowing back from the engine, but no air comes through when I apply air pressure from the rear after the air filter. Is there a check valve somewhere in there that's being regulated by the ASD relay? I don't see any attached. Thanks
Jul 29, 2010 at 2:58 PM
  • 110,251 POSTS
Are you sure you put the fuel filter on correctly? There is a check valve in it and if it is installed backwards, this could happen.
Jul 29, 2010 at 5:22 PM
DERRUMBE
Fuel filter is correctly installed. Problem is line back flushes, but does not allow fuel to go forward to injector rail.
Jul 30, 2010 at 12:21 AM
  • 110,251 POSTS
That is interesting. It is just a straight line.
Jul 30, 2010 at 4:33 PM
