2002 Dodge Caravan fluid
62,000 MILES • 6 CYL • FWD • AUTOMATIC
TP333
Hi, Ihave a 2002 caravan 3.3 w/ auto trans and would like to know if I can use dextron three in the trans? It calls for atf+4 as per owners manual. Thank you Tony
Apr 24, 2010 at 6:28 AM
BMRFIXIT
  • 19,053 POSTS
As emergency and or to add on just a bit
Try to avoid using it as much as if you can
Not recommended and not approved to be used in you tranny
Apr 24, 2010 at 11:19 AM
