2002 Dodge Caravan Engine will not run
27,000 MILES • 6 CYL • 2WD • AUTOMATIC
TONY47
The engine starts (not every time) runs afor a while then dies.
There is a 1391 code.
I have replaced the Camshaft Position Sensor.
I have looked at the Crank and Cam position sensors signal with a scope and the signals are there.
Is it possible the Powertrain Control Module is bad?
Please help
Sep 2, 2008 at 7:11 AM
BLACKOP555
  • 10,386 POSTS
could be the pcm or the cam, crank and computer need a relearn procedure.
also mind you if the belt slips by just as much as 1/2 a mark that it can be misaligned and cause that code to show up.
Sep 2, 2008 at 9:08 AM
