2002 Dodge Caravan Engine will not run
TONY47
  • 2002 DODGE CARAVAN
  • 6 CYL
  • 27,000 MILES
The engine starts (not every time) runs afor a while then dies.
There is a 1391 code.
I have replaced the Camshaft Position Sensor.
I have looked at the Crank and Cam position sensors signal with a scope and the signals are there.
Is it possible the Powertrain Control Module is bad?
Please help
Tuesday, September 2nd, 2008 AT 2:11 PM
BLACKOP555
  • 10,371 POSTS
Could be the pcm or the cam, crank and computer need a relearn procedure.
Also mind you if the belt slips by just as much as 1/2 a mark that it can be misaligned and cause that code to show up.
Tuesday, September 2nd, 2008 AT 4:08 PM
