2002 Dodge Caravan emission codes
113,000 MILES • 6 CYL • 2WD • AUTOMATIC
JIMAL
I failed a smog test and the code was po456 which I have seen relates to an evaporative system leak. I just got an oul change and they said I had a slight oil leak. Could this be the cause for the po456 code? Also on the smog test the only ECS test that I failed was "System Malfunction Light" I would appreciate any input.
Jun 13, 2010 at 10:26 AM
  • 75,988 POSTS
P0456 EVAP Leak Monitor Small Leak Detected
Get the evaporative control system smoke tested-could be the fuel cap
Jun 13, 2010 at 10:40 AM
JIMAL
Could an oil leak be related to this?
Jun 13, 2010 at 12:12 PM
  • 75,988 POSTS
No, -it has to do with gas vapors
Jun 13, 2010 at 4:43 PM
