2002 Dodge Caravan Dodge Caravan PCM...car or mechanic prob
KG713
2002 Dodge Caravan 6 cyl 105000 miles
I have a 2002 Dodge Caravan that has needed a PCM for some time but I thought ultimately died because of a seized engine. After installing new engine and ordering a flashed PCM, my mechanic said it still is not starting and needs another PCM. He has had the car for 5 weeks not the 2 days he promised. Also, from everything else I've heard and read, while expensive enough for a small part- it seems to be a pretty fast and easy fix. Is it normal to have such difficulty getting a PCM flashed and installed correctly???
Jun 24, 2010 at 12:26 PM
  • 75,988 POSTS
You have a technician problem here-take your vehicle and go somewhere else and get diagnosed by a reputable independent shop or dealership as you wish-
Jun 24, 2010 at 4:51 PM
