2002 Dodge Caravan DODGE
CINDYMET45
Engine Performance problem
2002 Dodge Caravan 6 cyl Automatic 200000 miles
I have put a new fuel filter and wires and plugs on it and it still act like it wants to cut off what do sugesst
Apr 14, 2010 at 5:20 AM
CH112063
  • 1,320 POSTS
Read the section labeled "How Does It Work" use a scanner to check it for codes. If none clean out the throttle body and remove and clean the IAC motor also, and the hole it mounts in. ok It gets dirt inbetween the throttle blade and body, this lessens the amount of air, dropping your idle efficiancy at closed throttle(foot off pedal). Good luck.
Apr 14, 2010 at 2:19 PM
