2002 Dodge Caravan dash intraments
H UNDERHILL
Electrical problem
2002 Dodge Caravan 4 cyl Front Wheel Drive Automatic
i have no dash intraments (guages,speedometer, etc.) every now & then they will come back momentarily and if i use the turn signal, they immediately go out again....
checked fuse box under the hood and all appear ok
Apr 23, 2009 at 7:01 AM
BMRFIXIT
  • 19,053 POSTS
Suspect bad cluster
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Apr 23, 2009 at 12:10 PM
CARADIODOC
  • 34,406 POSTS
BMRFIXIT is right, but they can often be repaired for this. The connector pins work loose. They can be soldered to the copper circuits to prevent the intermittent connections.
caradiodoc
Apr 26, 2009 at 7:53 PM
