2002 Dodge Caravan Cruise control malfunction
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
ECHAD93
2002 Dodge grand caravan 3.3L cruise light comes on when your push button to turn it on, but when I poush the button to set it, it doesn't engage but the light stays on. What would cause this?
Nov 7, 2009 at 8:48 AM
BMRFIXIT
  • 19,053 POSTS
Most common I found it to be the clock spring
do a code check
if air bag light on and or the horn dont work
for sure clock spring need replacement
Nov 7, 2009 at 11:48 AM
ECHAD93
Where is the clock spring located? Do I need to buy a code reader to check the codes? If so, what kind?
Nov 8, 2009 at 4:36 PM
BMRFIXIT
  • 19,053 POSTS
Clock spring is located in the steering wheel under driver air bag module
(remove air bag
remove steering wheel
remove clock spring )
air bag codes require a scanner and an OBDII reader will not get you air bag codes
stop by a local repair shop they should have the scanner to communicate with air bag module and pull any codes for you
Nov 8, 2009 at 10:04 PM
ECHAD93
horn works and air bag light is not on. would it still be the clock spring?
Nov 9, 2009 at 3:13 AM
BMRFIXIT
  • 19,053 POSTS
Usually it fail one after the other
but if all working makes me rethink the clock spring thing
and check if brake light switch need adjustment
Nov 9, 2009 at 10:25 AM
