2002 Dodge Caravan Code p0108
2002 DODGE CARAVAN
65,000 MILES • 6 CYL • FWD • AUTOMATIC
SASABOL
Just had the vehicle in shop to replace the MAP sensor. Two days later the same rough idle, stalling is occurring. Shows a code of p0108. What is the next and future step to resolve the problem.
Oct 25, 2009 at 7:26 AM
  • 31,937 POSTS
Hi there,
You will need to do a continuity check of the MAP sensor circuit back to the ECU, check the pins on the plug make sure that all are tight and clean, do this next, and don't rule out a faulty new sensor either this can happen as well, also if it is a remote mounted type, check the vacuum hose is in good condition as well.
mark (mhpautos)
Oct 25, 2009 at 2:51 PM
