2002 Dodge Caravan BUZZING SOUND WHEN IDLING.
JNAPIER
Noises problem
2002 Dodge Caravan 6 cyl Two Wheel Drive Automatic
After I hit a deer. Driver side headlight and hood is dented there is a loud buzzing noise when idling.
Other than that it seems to run just fine.
May 26, 2009 at 4:35 AM
  • 110,251 POSTS
Where is the noise coming form? Do you only hear it when the engine is running? Does it ever change?
May 27, 2009 at 1:56 PM
JNAPIER
Under the hood only when the engine is running.
May 27, 2009 at 10:39 PM
  • 110,251 POSTS
Make sure the fan isn't hitting anything. Also, check to see of the damaged light assembly is loose and vibrating.
May 28, 2009 at 12:05 AM
