2002 Dodge Caravan 2002 Caravan 2.4
135,000 MILES • 4 CYL • FWD • AUTOMATIC
WALLCRAWL
I have a 2002 Dodge Caravan. 2.4 liter 4cyl. The van has what seems like a miss at idle. It stumbles with an obvious miss intermitently while driving. Occasionally it will die when leaving from a complete stop. I have already replaced Plugs, Wires, and Ignition coil, with no change in condition. I have also replaced the Idle control valve. PCM maybe? Just checking to see if you guys know of any problems in this engine line.
Dec 22, 2008 at 2:35 AM
  • 110,251 POSTS
Hi:
There could be many things causing this. Make sure you check for vacuum leaks. also, have you had the computer scanned for trouble codes?
Dec 23, 2008 at 1:06 PM
