2002 Dodge Caravan
BILLOOKAUR
  • 2002 DODGE CARAVAN
2002 Dodge Caravan 6 cyl
I drove the van for half an hour and stopped in the parking lot. However I did not shut off the engine. After 15-20 minutes, I was talkng to someoone outside the van and smelled coolant. I stopped the car and checked under hood and noticed coolant had leaked. Then I drove again for 5 minutes and shut the engine but there was no leak after that. What had happened and why?
Thursday, November 26th, 2009 AT 1:06 PM
JDL
  • 16,098 POSTS
Thanks for the donation. Where was the leak? The engine temp may rise when idling for a long time. Does the radiator fan come on like it should? If the leak was around a hose, you might tighten a clamp. Some possibilities, radiator cap-- thermostat-- no flow/low flow through the radiator. Keep an eye on the temp gage. Any codes?
Thursday, November 26th, 2009 AT 1:57 PM
