2002 Dodge Caravan
EASYM1957
  • 2002 DODGE CARAVAN
Drive Train Axles Bearings problem
2002 Dodge Caravan 6 cyl Front Wheel Drive Automatic
I need to replace the passenger side cv axle are there any procedure or precautions I need to follow like some internal patr that might move
Monday, April 27th, 2009 AT 6:49 PM
  • 109,885 POSTS
Hi:
Replacing the axle is an involved process. I recommend getting a manual with step by step instructions and pictures to identify parts. For me to try to explain it over the internet allows too much room for error.
Wednesday, April 29th, 2009 AT 10:17 PM
  • 109,885 POSTS
Hi:
Replacing the axle is an involved process. I recommend getting a manual with step by step instructions and pictures to identify parts. For me to try to explain it over the internet allows too much room for error. I will tell you to be careful when removing and replacing the axle to the trans. If you nick the axle seal, it will leak.
Wednesday, April 29th, 2009 AT 10:19 PM
