2001 Dodge Caravan water pump replacement
13,000 MILES • 4 CYL • FWD • AUTOMATIC
LEELOW1
what steps do i take to remove old pump ? are the
pulley threads reversed ? any thoughts? thank you.
Jul 11, 2008 at 11:22 AM
BMRFIXIT
  • 19,053 POSTS
4 cylinders water pump driven by the timing belts and I would replace it too you need a special pulley puller to remove the crank shaft damper
https://images.2carpros.com/forum/automotive_pictures/99387_caravan_water_pump_4cyl_1.jpg
Mar 4, 2019 at 2:35 AM
