HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Caravan
Interior
Dashboard
2001 Dodge Caravan water leak
FARRELLRI
MEMBER
2001 DODGE CARAVAN
6 CYL
FWD
AUTOMATIC
160,000 MILES
There is a water under the dash caused by the AC.
Sunday, September 14th, 2008 AT 6:08 PM
MECHANIC
Hi there,
If this is water from the A/C system, the condenser drain tubes are blocked and this excess water (condensed humidity from the air) is not draining out, get the tubes check as they will be kinked or blocked.
Mark (mhpautos)
SPONSORED LINKS
Sunday, September 14th, 2008 AT 6:21 PM
Please
login
or
register
to post a reply.
Related Dashboard Content
2001 Dodge Caravan Dash Board
The Speedometer, Gas Gauge, Rpm And The Part That Shows Gear That Veh Is In Stoped Regerstering Unable To Tell Fuel Level Speed Or Rpm Or...
Asked by
wesley tribble
1 ANSWER
2001
DODGE CARAVAN
VIDEO
Kick Panel Removal
Instructional repair video
Whats Wrong With Dash Board Gages?
It Started With My Turning Signal Switch. It Only Worked Once In A While. Then It Stopped Completely. Now All My Insterment Panal Stopped...
Asked by
carolg_64
1 ANSWER
2001
DODGE CARAVAN
2001 Dodge Caravan Pulling The Dash On The Grand...
The Battery Died The Other Day And Then We Noticed That The Speedometer Needle Was Actually Under The Stop Pin Rather Than Above It. If...
Asked by
GorillaHawk
1 ANSWER
2001
DODGE CARAVAN
1996 Dodge Caravan No Power To Dash Panel When...
When Trying To Start Van (grand Es 3.8 Eng.) There Is No Power Going To The Dash Panel And The Van Starts And Then Immidiately Dies. Have...
Asked by
ellison57
1996
DODGE CARAVAN
1998 Dodge Caravan Dash Gauges Going Off And On
My Dash Guages Occasionally Go Off All At Once. They All Go To O Like They Have Been Unplugged. If I Hit Down On The Dash With My Hand Above...
Asked by
Martyuma
1998
DODGE CARAVAN
VIEW MORE
SPONSORED LINKS
Instrument Cluster Replacement
Seat Switch Replacement
Steering Wheel Removal
Online car repair manuals
