2001 Dodge Caravan van wont start
BUZZCAT228
  • 2001 DODGE CARAVAN
  • 6 CYL
  • 141,000 MILES
Just had a new engine put in two weeks ago and, and out of nowhere the engine tries to turn over but won't start, battery is fine , headlights power locks and such do not work, could this be relay problems
Tuesday, March 3rd, 2009 AT 12:51 PM
Do below to determine if its fuel or spark problem
Get a starting fluid/ether/better off gas in a spray bottle and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Tuesday, March 3rd, 2009 AT 12:58 PM
BUZZCAT228
Would a fuel problem cause headlights and power locks to not work? Seems electrical to me
thanks
Tuesday, March 3rd, 2009 AT 1:21 PM
No, the fuel problem has no relationship is to why the lights/door malfunctioning.
Its electrical alright could be relay/circuit breaker/wiring
Tuesday, March 3rd, 2009 AT 1:39 PM
