2001 Dodge Caravan tripped error codes
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
JUSTINMCMULLAN
my caravan tripped the following coeds 045.6 and 168.4 what is the definition of the codes i cant find out anywere
May 1, 2008 at 10:06 AM
MERLIN2021
  • 17,250 POSTS
How did you read codes like this? If these came up with an OBDII scanner, your PCM is giving erroneous codes and might be bad...codes begin with letters...P is the normally scanned code series for sensors related to emmisions. C for ABS, and U for body codes. Fill me in! What shows these numbers?
May 1, 2008 at 10:12 AM
JUSTINMCMULLAN
its p 0168.4 and p045.6
May 2, 2008 at 1:20 AM
MERLIN2021
  • 17,250 POSTS
P1684= Battery disconnecting durin last 50 starts.
P0456= Evap small leak detected.
May 2, 2008 at 6:28 AM
