2001 Dodge Caravan Transmission Problem or Something Else
ROUST1
Transmission problem
2001 Dodge Caravan Two Wheel Drive Automatic 123000 miles
We have had no symptoms of a possible transmission problem with our Dodge Caravan. My wife drove it to work with no problems. When she got in the car to come home the vehicle had no reverse or forward drive.
I checked the transmission fluid level and it was normal and the fluid had a reddish color, like new. The malfunction indicator light was on and stayed on, but did not flash. We towed it to a Dodge dealer and after pulling the oil pan, only, they said the transmission was burned up and had to be replaced. The cost would be $3,300 dollars. I am somewhat skeptical.
My question is, could there be other causes for this we should check before replacing the transmission?
Any information you could provide would be appreciated.
Thanks,
Don
Jan 31, 2008 at 1:57 AM
2CARPRO JACK
  • 11,533 POSTS
You can ask exactly what code/codes it had in the PCM. Usually if they drop 1st and reverse it isnt a good sign. Do you know of it will move in any gear?
Jan 31, 2008 at 4:50 AM
