2001 Dodge Caravan Thermostat?
HXAXTXE
  • 15 POSTS
Engine Cooling problem
2001 Dodge Caravan 6 cyl Two Wheel Drive Automatic 102k miles
Van started out simply leaking tranny fluid, then overheated..i thought coolant was low so i added 50/50...still overheated...now its leaking coolant as well
Jun 28, 2009 at 10:40 AM
BMRFIXIT
  • 19,053 POSTS
Coolant system need to be pressure checked
thermostat is one possibility
check for water pump leak
good luck
let me know
Jun 28, 2009 at 12:07 PM
HXAXTXE
  • 15 POSTS
Just a coolant pipe leak...thanks for the input!
Jun 30, 2009 at 11:49 AM
