Well after a new timing chain, cam positionig sensor, crankshaft positioning sensor, fuel pump, fuel pressure regulator, fuel filter, new plugs several times, all new plug wires, I still had the issue. Took it into the shop, come to find out it was the o2 sensor after the Cat converter. Was not putting up an error code, but was not functioning at all creating the ECM to push more fuel. After I changed the rear O2 sensor and a new Cat converter, the car runs fabulously again!
Sunday, March 7th, 2010 AT 8:13 PM
