Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Caravan
Engine
Serpentine Belt
Replace/Remove
2001 Dodge Caravan serpentine belt
2001 DODGE CARAVAN
130,000 MILES • 6 CYL • AWD • AUTOMATIC
AINDNAIDN
MEMBER
How do you change out the serpentine belt and wha tools are needed for a 2001 Dodge Caraven w/3.1L V-6 engine?
Feb 19, 2010 at 6:32 AM
DOCFIXIT
Experienced Mechanic
Hi Locate tensioner then with wrench pull spring off belt remove then release tensioner. Install in reverse order.
Hope this helps Thanks for donate
Feb 19, 2010 at 6:44 AM
AINDNAIDN
MEMBER
what size of wrench?
Feb 19, 2010 at 6:46 AM
DOCFIXIT
I don't know you need to try until it fits. I use a crescent wrench
Feb 19, 2010 at 6:50 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
