2001 Dodge Caravan Replace front window open/close motor
2001 DODGE CARAVAN
81,254 MILES • 6 CYL • 2WD • AUTOMATIC
MAGIC900
Both of the powered-windows on my dodge caravan are no longer working.
How do you remove the interior door panel to get access to the window???
How do you replace the window motor and regulator as required?
Are there anything else that need to be inspected or replaced to ensure that the powered windows will work m ore effectively in the future???
RSVP ASAP
Thanks,
magic900
Mar 9, 2008 at 12:31 PM
EPY
  • 19 POSTS
sometimes its just a fuse ( more info is needed) does your button make noise? sometimes in cold weather ice gets on and when you use the buttons it breaks the plastic cable ends and you dont need a motor,maybe just a new cable(if your lucky) if motors are needed have a drill and alot of patients.i am no mechanic but ive done this before and its a pain. it also could be your buttons shorted out..check the fuses. to get the panel off there are plastic buttons every few inches 2 flat screwdrivers on each side of them will pry them out, patients is the game.you may have special screw bits on the door handle .once you worked your way around the door youll feel resistance, that means you missed something, patience youll get it,dont tear it.good luck friend
Mar 9, 2008 at 9:12 PM
