2001 Dodge Caravan RADIATOR FAN
95,525 MILES • 6 CYL • 2WD • AUTOMATIC
JAYBAILEY24
The radiator fans quit working completely after intermittently working and I can't figure out which relay is the one that runs it. There is not one labelled radiator fan relay. There is only a fuse labelled radiator fan fuse. Help please
Dec 17, 2007 at 4:42 AM
E BALL
The relay you are looking for is not a plug in type. It is located under the air filter housing bolted to the frame beside the radiator.It is about 1.5 inches square and .5 inches thick and has a 4 wire plug for connection.I just changed it on my 1999 caravan.good luck
Jan 20, 2008 at 6:16 AM
