2001 Dodge Caravan Problem with turn signals
MUDDER6
Electrical problem
2001 Dodge Caravan Engine Size unknown Front Wheel Drive Automatic 115525 miles
I just recently started having a problem with my turn signals. When I use them now, all the lights on the dash will light up, along with the instruments which stop working. This lasts for about 20 seconds, then everything goes back to normal. The turn signals do not work at all (both left & right). Also, one time during an episode, my speedometer went clear up to the top and now it is not working. How do we reset the speedometer?
Jan 14, 2008 at 4:41 AM
BMRFIXIT
  • 19,053 POSTS
[quote:579cdb957f="mudder6"]Electrical problem
I just recently started having a problem with my turn signals. When I use them now, all the lights on the dash will light up, along with the instruments which stop working. This lasts for about 20 seconds, then everything goes back to normal. The turn signals do not work at all (both left & right). Also, one time during an episode, my speedometer went clear up to the top and now it is not working. How do we reset the speedometer?[/quote:579cdb957f]
Just a suggestion
check fuses
check relays and flasher
also locate BCM and unplug it
then plug it back
Jan 14, 2008 at 12:11 PM
