2001 Dodge Caravan power window and powerlock on driver's s
2001 DODGE CARAVAN
81,000 MILES • 6 CYL • FWD • AUTOMATIC
BILLANDJO
If I run the driver's side window all the way down, I can't get the window back up unless I open the door all the way and slam it shut. I believe there is a loose connection and the slamming reconnects it. So I need to know how to take the inside panel off in order to repair it. Can you help me?
Mar 11, 2009 at 9:18 AM
BMRFIXIT
  • 19,053 POSTS
Flat spot on window motor
is one possibility
need to remove trim and check
Mar 11, 2009 at 9:44 AM
